Ar 200 vertical out of focus and image enlarged
  • Papo
    • Oct 2008
    • 36
    Wierd looking copies no obvious binds in the optical unit or codes but from front to back magnification seems way out of spec.
    Anybody has had this problem?
    • 23008
    Is it possible that the MCU PWB has been changed? If so, have the appropriate jumpers been cut, so the machine knows it's an AR-200?
    Is the image compressed or expanded, and in which direction (feed [sub-scan] or cross-feed [main scan])?
    • Papo
      • Oct 2008
      • 36
      ar 200 jinxed
      its cross feed (main scan) out wack
        • 23008
        Problems with sub-scan magnification are related to scanner speed. Problems with main-scan magnification are related to image processing circuitry. Firstly, I would reseat all connections between the CCD and the MCU. It's most likely the MCU PWB. A distant second choice might be the CCD. =^..^=
