MXM565
  • copyguy1
    • Jul 2011
    • 142
    MXM565
    I was wondering if anybody else is seeing the issue of toner building up on the end of the drums. It looks like it gets baked on. We have replaced the drum units, DV units and drums and it still comes back fairly quick it is happening across the whole line of BW more on the 565.
  • OlliK1969
    • Nov 2016
    • 311
    Re: MXM565
    How old is the main charger unit ? How many copies ??
    • copyguy1
      • Jul 2011
      • 142
      Re: MXM565
      Main charge was replaced the same time as drum. This is about the 3rd or fouth time it has happened on this machine. It occurs about every 70k. Its is not the only machine we have doing this
      • techmann
        • May 2016
        • 41
        Re: MXM565
        Sharp had a theory that the waste toner bottle was not sitting in there right, causing the MC to short and pull developer. May be what you are seeing. I believe there is a bull on it
        • copyguy1
          • Jul 2011
          • 142
          Re: MXM565
          The machines are not pulling DV. I talked to Sharp and they said there are no reports of this
          • mojorolla
            The Wolf
            • 2630
            Re: MXM565
            What SIMS are you running after drums/ developer replacement.....?
            • copyguy1
              • Jul 2011
              • 142
              Re: MXM565
              Reset sim 24-4 and 24-5 and running 25-2 if DV changed
              • faxman28
                • 435
                Re: MXM565
                oem drum ? oem toner ? also are you doing calibration, 46-24 or 46-74. there is a density sensor that sits in transfer roller unit that reads patches on drum. your pic just shows front side of drum , is toner building up in cleaning section that the toner is not leaving the drum unit , customer making a lot of copies with adf open, I am also not seeing this issue , have mxm565/564 series that run 300k in 8 months and machines that run 1k a month ,
                • copyguy1
                  • Jul 2011
                  • 142
                  Re: MXM565
                  All OEM supplies, the other end of drum has very little build up. By the time the drum got to this point there is toner everywhere at that end the end of the MC is filthy.
                  • hellcat
                    • Jan 2012
                    • 126
                    Re: MXM565
                    Have you checked the transfer roller and roller unit? Do remember the charge roller basically rides on the drum. There are really only 3 things that touch the drum in this area. It looks like by replacing dv/drum units you eliminated the first two.
                    The red felt pads
                    the black plastic covers on each end of the magnetic roller in the dv unit
                    Charge roller on the side door.
                    • mojorolla
                      The Wolf
                      • 2630
                      Re: MXM565
                      44-2
                      44-6
                      44-27
                      44-26
                      46-74
                      Rinse and repeat.....
                      • lky1978
                        • Mar 2009
                        • 483
                        Re: MXM565
                        replace and install correctly with new drum side sheet (red colour) at both ends
