MX-M354N Err Failed to expand ARM9 prg
  • hafn
    • Aug 2008
    • 4
    #31
    Re: MX-M354N Err Failed to expand ARM9 prg
    Originally posted by Don N.
    repn1999- A million thanks. Have a great weekend!
    Hello
    I have a similar problem MXM 264, if you took off the machine on the SD Card
    • maxpaine89
      • Mar 2017
      • 2
      #32
      Hello Everyone!!!
      Does anyone have the file needed to be installed on the SD card?
      • Ratchet2501
        • Mar 2017
        • 206
        #33
        Around here we're dealing with the same problem on a MX-M264N. Model and serial (since I guess the os on the card is matched to the serial). $120 direct from Sharp later we have a new card.
        • oeshuron
          • May 2008
          • 259
          #34
          Does anyone have the image file for this model machine? We have one with the same error and do not have another of the same model. Needing asap.
          • oeshuron
            • May 2008
            • 259
            #35
            Capri
            MFP_PRG u301c1
            • oeshuron
              • May 2008
              • 259
              #36
              Able to use card from MX-M314N to make copy of. Was able to boot and then re-flashed firmware.
              • sht
                • Oct 2020
                • 7
                #37
                Originally posted by repn1999
                I am sending you a link to my server and a username and password. In the FTP folder will be all the stuff you need including the latest firmware for the MXM354 w/o HDD and instructions. Once you create the SD card you will need to do an emergency update with firmware provided. You may also need to reinstall the emanual or watermark firmware if it applies to that model. if your machine has a hard disk I dont have the sd card image for that one.
                web address
                Login
                SharpFTP
                Password
                Sh@rpman
                Hi
                this link don't work for me
                • rachid
                  • Oct 2023
                  • 1
                  #38
                  Capri MFP-PRG u301c1
