ARM257
  • JParker
    Technician II
    • Jul 2015
    • 51
    ARM257
    I am having an interesting CQ issue with an ARM257, black lines. I have a parts machine in good condition and have tried swapping parts. The issue is only from copies, internals are good. I cleaned the optics & mirrors, checked position. Replaced CCD unit and adjusted with no change. I then replaced the IMC board with no change again. I was hoping maybe someone else had seen this and had an idea..
  • Sharptech56
    • Feb 2016
    • 100
    Re: ARM257
    Try replacing the inverter pwb and the copy lamp .
    • rapidocument
      Multibrands Tech
      • Jul 2012
      • 381
      Re: ARM257
      Try another ribbon cable (flat cable) for the ccd.
      My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
      • ktucker
        • Apr 2012
        • 23
        Re: ARM257
        did you find a answer ?
        I have a 237 with the same issue
        • JParker
          Technician II
          • Jul 2015
          • 51
          Re: ARM257
          Unfortunately, no. That customer was not under maintenance and not willing to pay for further work. Have you done the CCD and imager?
          • lky1978
            • Mar 2009
            • 475
            Re: ARM257
            I got few units same problem and already scrapped, IMC board FAIL. Unfortunately,sharp DISCONTINUED production for the IMC BOARD on 237/277series
            • donking289
              • Mar 2017
              • 28
              Re: ARM257
              Fixed a couple of these with new ribbon cables.
