MX-M450N Scan Error CE-03
  • Buddy
    • Aug 2009
    • 285
    Hi Guys,
    I'm getting a CE-03 ("Consult your administrator or system administrator.") error when trying to scan. When I look at the web page for "admin settings" I get an error [936] "Scanning feature not enabled." The copier is showing the scan kit is installed. This also happens when I look at the "inbound routing settings. [936]
    I tried resetting the NIC. I also did an sp67-16 NiC check. It came back OK.
    Don't know if it would make a difference, but this machine has a security kit in it.
    Any ideas?
    THANKS,
    Buddy
  • bilyahn
    • Dec 2006
    • 1470
    Re: MX-M450N Scan Error CE-03
    Shouldn't make a difference with security kit or not. How did you verify that you had scan installed? Checking sim 22-10 is the best way. If you have a fax unit installed going to image send will work without scan being enabled (if by chance you were checking it that way).
    Good luck.
    Bil
    • coopers1305
      • Nov 2014
      • 49
      I would replace the MFP PWB, and you may need to put the product key back in.
      • Buddy
        • Aug 2009
        • 285
        Thanks for the responses guys.
        I got it working. Installed Sharpdesk. Still get the CE-03 code after a scan, but they're ok with it.
        I should have mentioned that their IT guy has them on a wireless router. Don't know if that makes a difference.
        Thanks again!
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          Thanks again!
          That series had a lot of problems with firewalls and bad firmware causing boot loops. There was a simulation (26-10) that when enabled would permit something like 500 scans without having the scan kit. The scan kit would show as active in the 22-10 display but it would only be the trial version. You might have something similar here.
