AR-M165 scanner driver
  • reyasuk
    Does anyone know where I can download the scanner driver for this machine?
    Many thanks
    Jen
  • bilyahn
    • Dec 2006
    • 1470
    If you have access to Sharpnet you can find it there. It is a very large file, 190MB. Sharp has a new tech website that also has the GDI Sharpdesk for this model but so far there have been issues when I have tried to download it. If you have the original setup discs it should have a version on them as this is the same as the ARM207 I believe. The download is not availible from SharpUSA website, sorry. Hope this is helpful. Good luck.
    Bil
    • reyasuk
      Hi there, thanks for your reply. I was asking this question for a third party and didn't have all the facts. It seems they have the driver but it won't install in WinXP but gives an error message - DLG_ERR. I gave up on Windows about 2 years ago so I'm a bit rusty on what might be the cause of this, but I'll keep looking. Once again, thanks for your advice.
      Jen
      • velandil
        Hello, I have the same problem with error while installing the driver on Windows XP. Maybe You have found any solution yet?
        Thanks for reply,
        velandil
        • reyasuk
          Hi, I wish I could say that I had found the solution, but I haven't so we'll both have to keep looking!
          Jen
