Sharp ARM207 Won't feed from cassette 1 only
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    I've just full serviced this machine, I washed (cleaned) all motor and feed gears and cleaned all solenoids and clean+lubed clutches but the (/)&&"#$%$ machine won't feed from cassette 1 (LTR), it does copy correctly from cassette 2 (LGL) and bypass, ADF works fine, I swapped the cassette 1 feed solenoid for another (working) one at no avail, I also swapped Main board with another working machine and *nada* (nothing happened), I even connected another solenoid from outside (in my hand) and doesn't energize when is supposed to, (I didn't bring my multimeter along).
    Any ideas on this ?
    thanks as always.
    Jaime.
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • JLSam
    • Jun 2015
    • 605
    Re: Sharp ARM207 Won't feed from cassette 1 only
    I know this sounds weird, but have you tried new Rollers? Also, what is the jam code? Does it sense paper? Does the tray lift the paper all the way?
    Does the pick up roller turn? Does it engage?
    Sent from my ONEPLUS A3000 using Tapatalk
    • rapidocument
      Multibrands Tech
      • Jul 2012
      • 381
      Yes, the feed tires are good, and the paper cassete lifts up ok. The copier feeds correctly if I help (by hand) the solenoid to free the feed clutch turn when it has to,
      it does sense paper ok and it does sense the cassette is in, (I already checked that too),
      the problem is that there is no voltage coming to the solenoid, it doesn't move at all.
      • ZOOTECH
        Senior member of CRS
        • 3375
        Without a meter, you'll have a hard time isolating the trouble (loss of return or signal levels). You are left with 'shot gunning' parts as your original post suggest.
        • dwarf
          • Oct 2012
          • 168
          long shot here...it may be a photo sensor in tray 1 PF assy...maybe switch all the sensors from one tray PF to the other PF...this model ALWAYS had tray 1 problems...
            • 23008
            Here are two line entries that might help:
            Misfeeds from tray #1, no paper is found on AR-200. The pickup clutch binds & does not let the pawl release. Clean and re-grease the tray #1 pickup clutch.
            Misfeeds from tray #1, no paper is found on AR-201. Unsuitable cardstock is loaded in tray #1, and cannot feed out. Load suitable paper stock.
            • copiertec
              • Jan 2016
              • 2206
              If I remember correctly there was updated paper tabs the paper trays because the paper used to hang on the metal tabs, especially from tray 1. I see you cleaned the clutches... that factory grease caused a ton of issues with jamming and not allowing the spring to return to position, I used WD-40 instead with great results, instead. I forget the part #'s for the paper tray tabs. Also, if I remember correctly, Sharp came out with updated rollers for the AR-207 different shape....But, your issue is tray 1 solenoid not firing.. seems you done all the obvious, I would test and see if your getting proper voltage to it. If you have the wiring diagram, handy I would trace it back to where it gets its voltage from, possibly a power supply issue?
              • rapidocument
                Multibrands Tech
                • Jul 2012
                • 381
                Today I'm back to this oldie,
                I'll let you know what develops.
                Customer very unhappy with this box, seems previous techs had issues with it too,
                (Customer requested a new machine estimate though).
                • JLSam
                  • Jun 2015
                  • 605
                  BW mfps, recommend 503 family. They are really solid mfps.
                    • 23008
                    Personally I would not use WD40, since it is not a lubricant. IBM23 or Mobilgrease28 work nicely.
                    This is not a machine that deserves a lot attention. They were jammomatics right from the beginning. I would concentrate on making that machine go away. =^..^=
                    • pohaku
                      • 17
                      I bet twenty bucks your resist roller clutch is broken
                      • dwarf
                        • Oct 2012
                        • 168
                        I'm pretty sure this has a resist pad and not a reverse roller and clutch for the cassette paper feeds...
                        • techwurk
                          • 127
                          Yes these have sep pads not reverse rollers. make sure the "plastic frame" where tray one clutch and shaft are not in fact broken.
                          If so then replace the copier
                          When I started servicing copiers they used toaster ovens for fusers.....I'm old
                          • harleyrider
                            • Oct 2011
                            • 348
                            Any arm207 I have ever seen has half moon shaped feed rollers driven by a spring clutch fired by a solenoid controlled by pcu pwb.
