Help with code MX-4141N
  • campy
    • May 2012
    • 315
    I don't know why I can never find what I am looking for in the manual. I am getting a message that says Maintenance Code TA. I thinks it's the Transfer belt but not sure. If it is, what needs to be done and if you have the part numbers I would appreciate it. I am more a Canon guy but I have a customer that has 6 Canons and 2 Sharp 4141. It has 431K on it.
  • driving lots of miles
    • Jun 2016
    • 399
    Re: Help with code MX-4141N
    TA stands for the replacement timing of the fusing cleaning
    roller, the filter and PS paper dust removal cleaner. there are
    usually more codes also involved and they should show up on the machine.
    • harleyrider
      • Oct 2011
      • 348
      look in the maintenance section .
      • JLSam
        • Jun 2015
        • 605
        It's in the service manual. "Display of maintenance execution timing". Section 9 - 2.
        Basically, it's DK and VK combined. Needs the new black kit.
        Developer, drum, blade, and charger.
        Drum: mx31nrsa
        Kit: mx510mk
        Dev: mx51nvba
        Reset codes in sim 24.
        Good luck.
        Sent from my ONEPLUS A3000 using Tapatalk
        • JLSam
          • Jun 2015
          • 605
          Fusing cleaning would be FK3.
          But I agree, he should check for other codes in MFP status.
          • copierdude1114
            • Dec 2015
            • 29
            You can always check sim 22-13 if you aren't sure, show's you the remaining life %'s
            • mttech
              • Mar 2014
              • 127
              If you have access to the copier you can print out a sim 22-6. On the first page will be the sim 22-13 info. This will also give the percentage of life use.
              • dwarf
                • Oct 2012
                • 168
                A. Maintenance
                Maintenance required. Code: TA 0 (Print continue) Maintenance counter
                (Total)
                When the SIM21-1 set value is reached. Enable
                1 (Print stop) When 90% of the SIM21-1 set value is reached.
                Maintenance required. Code: TA 1 (Print stop) When the SIM21-1 set value is reached. Disable
                Maintenance required. Code: CA 0 (Print continue) Maintenance counter
                (Color)
                Maintenance required. Code: CA 1 (Print stop) When the SIM21-1 set value is reached. Disable
                Maintenance required. Code: AA 0 (Print continue) Both of total and color When the SIM21-1 set value is reached. Enable
                Maintenance required. Code: AA 1 (Print stop) When the SIM21-1 set value is reached. Disable
                Display content
                Display condition Print JOB
                SIM26-38-A set value Counter name Counter value Enable/Disable
                Maintenance required.: TK1 0 (Print continue) Primary transfer unit print counter When 300K is reached. Enable
                1 (Print stop)
                Display content
                Maintenance required.: TK2 0 (Print continue) Secondary transfer unit print
                counter
                When 300K is reaches. Enable
                1 (Print stop)
                Display content
                Maintenance required.: FK1 0 (Print continue) Fusing belt print counter When 300K is reached. Enable
                1 (Print stop)
                Maintenance required.: FK2 0 (Print continue) Pressure roller print counter Enable
                1 (Print stop)
                Maintenance required.: FK3 0 (Print continue) Fusing web print counter Enable
                1 (Print stop)
                Display content
                SIM26-38-B set value Counter name Counter value Enable/Disable
                Maintenance required.: FK3 0 (Print continue) Fusing web print counter When 300K is reached. Enable
                1 (Print stop)
                Maintenance required.: FK3 0 (Print continue) Fusing web print counter When Web end detection is ON Enable
                1 (Print stop) Enable
                Display content
                Display condition
                Print JOB
                SIM26-38-A Enable/Disable
                Maintenance required.: DK 0 (Print continue) OPC drum print counter (K) or
                OPC drum accumulated rotation number counter (K)
                840K is reached
                or 200K is reached
                Enable
                1 (Print stop)
                Maintenance required.: D (C/M/Y) 0 (Print continue) OPC drum print counter (C/M/Y) or
                OPC drum accumulated rotation number counter (C/M/Y)
                840K is reached
                1 (Print stop) or 160K is reached
                • fireater
                  Repair God? not quite
                  • Apr 2006
                  • 253
                  maintcodes
                  D (k/c/m/y) drum the letteres are cyan magenta yellow and black
                  V(k/c//m/y) developer .. letters are same as drums
                  TA maint black
                  CA maint colour
                  TK1 primary transfer
                  TK2 secondary transfer
                  TK3 not in book PTC
                  FK1 Fusing belt
                  FK2 Lower Pressure roller
                  FK3 Fusing Web
                  I fix copiers ...Well Sorta
