MX-B401 Glass removal??
  • Buddy
    • Aug 2009
    • 285
    Hi All,
    Well, in over 30 years I've never been unable to remove a glass to clean the optics. What am I missing? (I even downloaded the manual, but all I saw was removing the scanner unit?)
    Thanks,
    Buddy
  • JLSam
    • Jun 2015
    • 605
    Re: MX-B401 Glass removal??
    It's not fun. You it will take you maybe 30 mins to remove it.
    Yes, you need to remove the entire scanning unit.
    Sent from my ONEPLUS A3000 using Tapatalk
    • JLSam
      • Jun 2015
      • 605
      I shouldn't say this. But twice I noticed lines, I saw the piece of dust, so to avoid removing the entire scanner assembly, I drilled a hole, and blew air. It worked.
      I plugged the whole with a small plastic screw, sharpied it black, and went on my way.
      Just a thought.
      • driving lots of miles
        • Jun 2016
        • 399
        The B & C 402's are the same way also. Fortunately they are sealed really well and in a clean environment you don't have to clean the optics unless there is a problem.
          • 23008
          IIRC you have to remove the scanner and flip the assy upside-down to access the screws. You should have heard the gasps from the other Sharp techs when they saw what I was doing. "I won't have to do that, will I?"
          Only if you want to clean the scanner optics. =^..^=
          • Buddy
            • Aug 2009
            • 285
            GEEEZ, what was Sharp thinking?? Nothing stays clean forever, even if it's in a sealed unit.
            Thanks guys.
            • JLSam
              • Jun 2015
              • 605
              Thanks guys.
              Good luck. Not fun the first time.
              ๐Ÿ˜’
