Sharp MX-M453N email scanning question
  • Dave
    Retired 25 years exp.
    • 35
    We are scanning to email a high volume of documents and when we have a document feed jam the file sends and we don't want it to because obviously it's incomplete. Is there a setting we can change or a work around we can do so the transmission doesn't take place until we are done scanning? Thanks!
    And yes, I am a technician, I'm just not finding the answer fast enough on this one.
  • gregoryrbrts
    • Mar 2017
    • 33
    Re: Sharp MX-M453N email scanning question
    Try this, under condition settings of scan mode there should be the job build feature if I am not mistaken. you can use that as sort of a preview while your documents are scanning In. Also if Im not mistaken when the doc feeder jams it should be a block on the screen to yes or no continue your job.
    • Dave
      • 35
      Greg, I'll check it out tomorrow and let you know. Thanks!
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        You want to use Job Build, under Special Modes:
