SHARP MX-M565N, Crumpled paper every time you print or copy (2 sided).
  • crisjue
    • Apr 2017
    • 10
    Every time i want to print or copy with 2 sided, it's always crumpled output. I changed the consumable parts (drum, main charger kit, web cleaning kit, heat and pressure rollers) but still the problem occurs.
    What seems to be the problem?
    • 22999
    Re: SHARP MX-M565N, Crumpled paper every time you print or copy (2 sided).
    Have you tried fresh paper? Most wrinkling problems on two-sided are associated with high moisture level in the paper. =^..^=
      you never said WHERE is was crumpling the paper only when you do two sided... why change out all those parts if it wasn't doing it on single side? you should have gone right to the parts for duplexing the job.
      • spanky
        • Sep 2012
        • 468
        See attached bulletin
        • ZOOTECH
          Senior member of CRS
          • 3375
          Yeah, what jam code is showing; I have seen the duplex motor reverse on occasion, giving a DPPD1 jam, maybe yours is not turning at all.
          • dwarf
            • Oct 2012
            • 168
            the fuser entrance guides may be built-up with toner...that will cause wrinkles in the copy...
              he still hasn't replied as to WHERE it is jamming .. only when doing 2 side.. said he changed hot + pressure rollers.. I hope when someone does that they inspect the guides and rest of fuser for issues.
              • crisjue
                • Apr 2017
                • 10
                no jamming is occured. but the output paper is wrinkled.
                  • 22999
                  ... ahem ... MEDIA!!
                  • jon jennings
                    • Aug 2011
                    • 51
                    Have you solved this? I am having this trouble on two machines. When it jams it will be in the fuser rear transport guide. It will make a wavy copy when doing letter copy but jam on letter R or legal. I have ordered the guides and roller since the part numbers have changed, but have not installed them yet.
                    • dwarf
                      • Oct 2012
                      • 168
                      if it makes the first side but jams on the 2nd side when using 8 1/2 x 11R or legal, it is probably a switch or sensor in the ADU...or some sort of condition that slows the paper down...or a dirty fuser...
