Al 1041 H4 Reset
  • mkopoiuy
    • Mar 2008
    • 54
    Al 1041 H4 Reset
    anyone could tell me how to reset H4 code.
    thanks.
  • MHeon71
    • Oct 2008
    • 489
    You should be able to get into TC by entering clear - density select - clear - density select and once in simulations scroll to 14 and execute.
    • techarpcanjr
      unblocking h4 in all Sharp AL-16XX
      you need to get into simulation mode as follows clear key - density select key - clear key - density select key, as fast as you can do it. copier's display is off.
      now copier is ready for resetting that code
      type 14 then start
      copier will auto shut down
      and it will be ready for copying
