ar 5316
  • Gab
    • Aug 2015
    • 668
    ar 5316
    toner drops at the point where recycling from drum unit to dev unit.
    I checked toner and i noticed that there is too much toner at this point. Like it doesn't distribute toner evently in toner bottle.
    It happens with every toner bottle.
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: ar 5316
    Old machine...
    If it's the machine I'm thinking of, the glue on mylar near the dev roller lets go and lifts toner out of the dev unit.
    Don't know if I've help you or not....
      • 22997
      Re: ar 5316
      From what you're describing it sounds as though the developer is dead. Can you even get developer for a 5316? I doubt it. =^..^=
      • Gab
        • Aug 2015
        • 668
        Re: ar 5316
        I have replaced developer 3 months ago and since machine made about 6k copies.
        • rapidocument
          Multibrands Tech
          • Jul 2012
          • 381
          Re: ar 5316
          This machine doesn't recycles toner, the used toner goes to a waste reservoir in the toner cart.
          the waste must be full by now and toner is scattering out.
          Or
          check in the drum unit the used toner paddle (conveyance shaft) at the very end there must be a
          foam ring, by the time this thing has worked it won't be surprise that this foam has disappeared
          and now you have toner leaks at this point.
          My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
