Mxm565 build up on fuser guide
  • Sharptech0892
    • Aug 2011
    • 79
    [Jamming] Mxm565 build up on fuser guide
    Just curious if anyone has seen a problem with toner sticking to the exit area of fuser? Any fixes? I have that one that only takes a few days to have it again.
  • dwarf
    • Oct 2012
    • 168
    Re: Mxm565 build up on fuser guide
    it may be time for a PM with a drum and developer...or at least clean it and recalibrate...
    • mansart
      • 852
      ditto above.....
      we are seeing the same thing but only on machines we are "stretching"
      • ktucker
        • Apr 2012
        • 23
        we are seeing the same issues with our high volume boxes. pms are done on time
        • Sharptech0892
          • Aug 2011
          • 79
          Yep, same with this one, volume is high on it also. Even tried a new fuser.
          • copyguy1
            • Jul 2011
            • 142
            You may want to look at the DV unit. They did change the doctor blade.
            • michaelc
              Field Tech
              • Mar 2011
              • 590
              Just my 2 pence (im english) a lot of people dont clean the dev filters on the black and white machines.
              If its high volume you can sometimes get to stage where the guides can loose the curvature so the paper does not flow over it but crashes and passes with out jamming. You can only really tell when putting them side by side.
              It didn't say that I couldn't do it in the manual.
              • sharpie
                • Feb 2011
                • 182
                These units seem to pull developer and toner from the rear side of the drum which accumulates on the fuser guide. check your charge corona and drum blade just outside the image area on the drum.
                • OperatorError
                  • Aug 2017
                  • 21
                  I am following this thread closely. We have one doing this. We have changed the drum, fuser, MK, dev and dev unit. The strange thing is the customer has never said there is toner smearing on their prints. But after 20,000 sheets or so they will get jamming issues due to the amount of toner built up on the guide above the fuser (still part of the fuser unit)
                  We have monitored the power and have seen some dips below 100v. So we have suspended anymore troubleshooting until the customer addresses this.
                  • mojorolla
                    The Wolf
                    • 2627
                    I see a new bulletin that was issued yesterday. Change of DV unit to deal with toner dispersion from DV unit.
                    MFP-TB-1643
                    There is also a bulletin for the transfer unit, MFP-TB-1567
                    • kev577
                      • May 2016
                      • 12
                      • moose55
                        • Mar 2017
                        • 143
                        As stated earlier, I would change the transfer roller, but there were also a few bulletins about the developer unit dumping developer. I have replaced the developer unit on a few higher volume machines due to this, and the newer developers seem to be sturdier with the updates.
                        The Moose is loose!!
                        • MylonG
                          Yes there are Tech Bulletins to updated DV units and Transfer units. Also we found that roller 6 wears down allowing the paper to rub against the guide and build up the toner. Replace roller 6.
                          • Dcopyman
                            • Apr 2020
                            • 34
                            POD1 Jams due to Toner Adhesion to Fuser Guide Plate
                            Bulletin Number: TT-102517_1
                            Models: MXM364N, MXM365N, MXM464N, MXM465N, MXM564N, MXM565N
                            Date: 10/25/2017
                            Priority/severity: Medium
                            Summary: Replace transport roller NROLR1868FCZZ.
