Sharp MX-6050 does not boot.
  • chatkal1
    • 13
    MFP does not boot. Green LED next to a power button blinks. MFP does not respond to power button.
    Any thoughts?
  • Hansen88
    • 1069
    Re: Sharp MX-6050 does not boot.
    I have had similar issues as those in different model sharps that have been caused by a bad sd card.
    • chatkal1
      • 13
      SD Card????
      Do you mean mSATA SSD?
      • mansart
        • 854
        MX6050 does not use an SD card.
        • chatkal1
          • 13
          Originally posted by J THUGGA
          I have had boot issues with several different models and it was the SD card every time, definitely try a new SD card first. They are machine specific so you will have to order the MX-6050 SD card from Sharp.
          #THUG#
          There is no SD card on this MFP
          • mansart
            • 854
            First thing to try would be "emergency firmware".
            • J THUGGA
              GANG BANGER
              • Jul 2017
              • 6
              You need to look in your manual there are solutions to simple issues like this, don't be afraid to open it... Open your mx-6070 service manual go to self diag and trouble code 7-40, there are 2 solutions, yes everyone is right there is no sd card, it's either the SCN-MFP PWB or the mSATA SSD (hard drive)....try mSATA (hard drive) first if that doesn't work then replace SCN-MFP PWB, they make manuals for a reason peeps.
              • xring1958
                • Mar 2016
                • 166
                We had a 3070 do this to us. Sharp said to replace the MSATA Board ( this is the new SD) and the Flash ROM plus there is a very small ribbon cable on SCN MFP Board that they said needed to be reconnected. We did this and nothing changed. Ended up replacing SCN MFP Board & that did the trick.
                Note if machine takes a while to shut down do not kill with power switch just wait it out. This apparently is one of things that might cause this.
                Good luck
                • mansart
                  • 854
                  • J THUGGA
                    GANG BANGER
                    • Jul 2017
                    • 6
                    Good luck
                    Your mind as well have just copy and pasted my answer
                    • harleyrider
                      • Oct 2011
                      • 348
                      Check TT-051816_1R1
                      • xring1958
                        • Mar 2016
                        • 166
                        Your Might was autocorrected to Mind
                        Many times the manual offers a lot of might be solutions and actual experience may narrow down the possibilities.
                        If every time I replaced the first thing recommended as possible in a manual my Boss would fire me for wasting money.
                        When you get the chance to add up several experiences you get a better understanding of the issue. That is the benefit of forums like this.
                        That being said it shouldn't replace normal troubleshooting techniques including proper use of the service manual.
                        • Jkearbey
                          • Nov 2016
                          • 15
                          The only way to tell for sure is to check the LED indicators on the MFP PWB. SHARP has a good tech tip /bulletin that explains the LED indicators for a dead machine, TT-051816_1R1. It will help you narrow down exactly what the faulty part is. I have run into this problem one time and it started with an E7-90 error code and eventually wouldn't boot at all. In my case the M-Sata card was corrupt and once replaced the machine booted up normally.
                          SHARP now makes it clear that a power cycle is needed before updating firmware, See TT-012317_2 to get more detailed instructions. I don't like this step because it is a change from how its been before and old habits die hard. They claim that if this is not done you could get a Black LCD or E7-90 or both.....not good!
                          Good Luck
