AR-M355U - No Network Connection
  • oeshuron
    • May 2008
    • 259
    Tech went out and replaced fan for L4-30 and now customer is saying no network access. IT dept as reset network as well as tried static ip. Lights are on and flashing but can't ping from machine. Wanted to set link negotiation to manual but am not sure if thats possible in these machines.
    Re: AR-M355U - No Network Connection
    Originally posted by oeshuron
    Tech went out and replaced fan for L4-30 and now customer is saying no network access. IT dept as reset network as well as tried static ip. Lights are on and flashing but can't ping from machine. Wanted to set link negotiation to manual but am not sure if that's possible in these machines.
    did your tech print out the status page? What is the ip address mentioned? did he try hooking a laptop up to it w/ a cross over cable and try connecting.. that would bypass the customers network and prove it is the network or the printer/copier
    • oeshuron
      • May 2008
      • 259
      Was the machine. IP address wouldn't print out properly. Ended up finding the sim 55-3 that i was looking for doing search but tech ended up re-seating connections on the mfp and that fixed the issue.
      • lky1978
        • Mar 2009
        • 483
        Try to reseat the nic card, use simulation 22-10, check for printer expansion kit, is it enable?
        • pohaku
          • 17
          AR-M355u is not a network copier. You can make it one. The ARM 355 "N" is the network copier..
            • 22999
            That was my thought. I can just imagine some IT guy deciding that he was going to connect this old POS. He sees the RJ45 so naturally he thinks it can print. When it doesn't he immediately blames the most recent tech: "You broke my machine!" Too bad the AR-M355U doesn't print. You can change the MFP board to make it an AR-M355N or use a parallel to TCP/IP print server quite cheaply. =^..^=
