PRI_JAM on Sharp MX-4070
  • SRF
    • Oct 2014
    • 10
    [Jamming] PRI_JAM on Sharp MX-4070
    can anyone shed some light on this jam code?
    PRI_JAM - Image preparation wait time- out
    power cycled machine started working fine again.
  • VBS Tech
    • Nov 2016
    • 12
    Re: PRI_JAM on Sharp MX-4070
    we had the same jam code on a mx-m264 the other day... it ended up being a failing sd card, we replaced it with a new one and all is working fine now. We have had many sd card failures on this series of machine but this was the first time we had one partially fail. It would make 4 or less copies no problem but if you made 5 it would spit out 4 like normal then sit there and think about the last one for about a min. then show a jam with the PRI_JAM code. I hope this helps
    • SRF
      • Oct 2014
      • 10
      sooo many SD card failures, we have just been rewriting them with HDD-GURU its a great way to save money not buying sharp SD cards for $100 a piece. I was happy to learn they did away with the SD cards and replaced them with Msata cards. the Msata cards are doing the same thing however. I guess I wont be surprised if this machine fails to boot soon.
      • PrintToPDF
        • Oct 2015
        • 27
        pri_jam only coping from OC glass: check/replace ccd unit.
        • ZOOTECH
          Senior member of CRS
          • 3375
          If this code shows when printing, it is a driver issue. Clear out your print memory (I think it's 67-14 or 17); reseat memories and verify if the 'jam' code shows during printing or copying.
          • PrintToPDF
            • Oct 2015
            • 27
            for print, back up network settings under device cloning prior to clearing printer controller memory. As mentioned above, it's 67-17. It removed some settings.
            Memory is on board on this MFP.
            • JR2ALTA
              • Feb 2010
              • 2030
              Sharp hardware is weak as ****. No reason in 2017 we should be getting these logic errors. Mechanically pretty solid, although, why they change feed rollers is complete idiocy.
