MXb201d jaming at paper exit
  • aaserudk
    • Aug 2025
    I am working on a MXB201d that is jamming almost every page and the paper is stopping just short of the exit rollers. I have cleaned all rollers and spring clutches. taken off the scanner unit and cleaned or replaced rollers and sensor. new fuser and right side door. Any thoughts?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MXb201d jaming at paper exit
    What jam code are you getting?
      jam codes would be helpful.. you have mentioned scanner and fuser jamming at exit.. I have to assume you mean at exit of the machine and not scanner? if so why work on the ADF/Scanner section?
      • JLSam
        • Jun 2015
        • 605
        Show us the 22-6.
        Also, have you tried sim 6 aging to determine whether the jam is from mechanical problem or electrical problem?
        Sent from my ONEPLUS A3000 using Tapatalk
        • harleyrider
          • Oct 2011
          • 348
          on that model you have to remove scanner to get to exit rlrs and sensor is what he is saying. if it were me I would check exit sensor at the pcu pwb.
          • dwarf
            • Oct 2012
            • 168
            it might be a worn exit switch actuator (the one in the fuser section, on the flap of the fuser)
