MX4070 - Single Sign On Not Enabling in Active Directory Environment
  • nobody-here
    • Mar 2008
    • 237
    Hi guys-
    This is the Scenario:
    MX4070 into a network with Active Directory. I registered the machine to use Active Directory for user logging and is working good, but only for copy.
    I can't enable Single Sign On on the PC Drivers to authenticate printing.
    Machine is into AD, and Auth is working for copy by login through the LCD Panel.
    When I install printer driver, after "auto Configuration" there is no "Single Sign On" can't be enabled in any way.
    I checked AD and Domain Controller. Seems good
    What should I need to check.
    Thank you so much for your help.
    29 rouge unpair manque.... cous cous....
  • nobody-here
    • Mar 2008
    • 237
    Re: MX4070 - Single Sign On Not Enabling in Active Directory Environment
    Originally posted by nobody-here
    Hi guys-
    [Solved]
    Firwmare must be updated and printer driver must be newer than may 2017.
    Regards
