Hi guys-
This is the Scenario:
MX4070 into a network with Active Directory. I registered the machine to use Active Directory for user logging and is working good, but only for copy.
I can't enable Single Sign On on the PC Drivers to authenticate printing.
Machine is into AD, and Auth is working for copy by login through the LCD Panel.
When I install printer driver, after "auto Configuration" there is no "Single Sign On" can't be enabled in any way.
I checked AD and Domain Controller. Seems good
What should I need to check.
Thank you so much for your help.
