Sharp MX453 Stuck in Waiting when duplexing!!!
  • Lbcoaster
    • 43
    [Misc] Sharp MX453 Stuck in Waiting when duplexing!!!
    Sharp MX 453 When you do a 2 to 2 or 2 to 1 duplex it get stuck in job status saying Waiting
    Things we have tried:
    Duplex is not disabled
    Replaced CIS for second side
    Replaced Doc Feeder
    Format HDD
    Any ideas will be greatly appreciated!
    Steve
  • techwurk
    • 127
    Re: Sharp MX453 Stuck in Waiting when duplexing!!!
    I Work on these a lot and never saw this problem, have you tried replacing the memory?
    When I started servicing copiers they used toaster ovens for fusers.....I'm old
    • Lbcoaster
      • 43
      Thanks I will try that which one?
      I don't think it is the SD Card on the Doc feeder might be the SD on the Scanner control PWB or the Dimm 1, 2 or 3?
      Steve
      • techwurk
        • 127
        No SD cards on a 453. Memory chips are labeled "LF" on MFP board, try re-seating or replacing to see if that solves it.
        • Lbcoaster
          • 43
          Thanks I will give it a try!
          • dwarf
            • Oct 2012
            • 168
            update the firmware...maybe format the HDD...
