I have a machine I am working on a MX-M363 that for some unknown reason will not print out a 8.5 by 7 inch document without messing up the margins. I wish I had a printout from the machine to show but sadly they didn't have a way of test printing on it (company secrets blah blah blah). On the lines where it should be printing it is off by about a tenth of an inch. Which they have been able to print these for some time now no problem and when I have the computer send the print to another machine (also a mx-n363n) it comes out just fine. I have tried using another tray and adjusting margin settings etc but no dice. I tried cloning the machines settings from the other that works fine but no dice on that either. The only difference I can see is the firmware is different. I don't see anywhere in the settings where it could be messing this up. Thoughts? I want to try the firmware angle but I'm having a hard time with that due to sharp systems access since I have to get firmwares through my supplier (which hasn't responded yet).22-6 scan mx-m363n.pdf
MX-363N printing offset
Re: MX-363N printing offset
If it was working previously and with over 500k on the machine I would look at registration rollers. It might have a slight slip in the rollers or clutch that is effecting the smaller paper. -
I have a metric crap ton of rollers around here but not the one for that machine's paper register (Sharp NROLR1526FCZZ). Which Im taking it for granted that part of the process is the rollers and sensors that grab the paper from the tray or is that further down the line? On the 50-10 menu, hate to ask kind of a newby question but if I wanted to tweak the settings to shift it down just a bit which settings would adjust that? Or would that be the lazy shortcut only going to work for like a day or two answer?Comment
FYI-I've been out of practice since retiring 16 months ago; so take this advice at you own risk."You can't trust your eyes, if your mind is out of focus" --Comment
Just played with those settings on my machine here a 4100 and I see what you're getting at. Although my training was bad enough that I didn't know that calibration test was available. I will update this post tomorrow with whatever results I get from cleaning rollers and running that calibration. Between the two of them I will either make it worse or fix it *shrugs* Thanks either way for the ideas.Comment
Which margin is off? Feed direction or crossfeed? Is your tray set up to the appropriate custom paper size?
If it's crossfeed, it may be as simple as a mechanical tray adjustment.
If it's in the feed direction, perhaps you've got some binding in the registration unit (paper stop assembly)? Or perhaps a stop position adjustment.If you'd like a serious answer to your request:
Update: The 50-28,12 and 10 sims were kinda helpful but the result was the same. Under the 50-28 sims some of the reads were ER(ER) which I'm guessing is short for Error but I'm off to the google machine now for that one. Due to my lack of knowledge I was unable to figure out the paper stop/registration location/issues but Ive got the right size rollers on order so we shall see.Comment
Tried a different tray and as far as I know tray two has had these same size sheets of pre-prints in them since the machine was bought. And even switching trays and loading settings from a known good machine no dice. And according to the 22-6, it has had over eighty thousand through it thus far. As for the paper stop and ER on the sim 50 reports, still somewhat clueless since the manual doesn't give me enough to go off of from what I've read thus far. Feed direction is where it's missing the mark, going too far by maybe a tenth of an inch which on these pre-prints is just enough to make the whole thing look "unprofessional" per the customer. Weekend is almost here, definitely ready to head to the shooting range and blow off some steam at around a thousand yards. Might even drag the Savin copier someone dumped off on us with me.Comment
now that sounds therapeutic. Take a few shots for me. =^..^=If you'd like a serious answer to your request:
Back at it like a krak addict.
On the one it says Error 1,3,3,0,0 but unfortunately I have no idea what needs cleaned or kicked for that one.Comment
I haven't worked on this model in quite a while, but I do have something to offer. I first noticed on the Sharp Tiger, JupterI and DragonI series that the sub-scan image registration adjustment in the service manual made no sense at all.
Now we've all seen bad translations (anyone for a lump unit or deveroper assembry?), but this is 4 pages of incomprehensible gibberish. Modesty aside, I think I'm pretty good at following a manual, but after spending a whole day trying to puzzle it out, I just gave up and figured out my own procedure.
I'll be the first to say that my procedure is repetitive, but you do end up with a 100% ratio image that registers properly on the paper. The procedure I wrote was composed for the Tiger, JupiterI, and DragonI, but maybe you can stretch it to fit your situation (It is a JupiterIII after all?):Attached FilesIf you'd like a serious answer to your request:
