sharp mx-m565n water mark
  • clark
    • Sep 2016
    • 109
    [Electrical] sharp mx-m565n water mark
    I got the water mark to down load. I go to 49 then to water mark. touch display but for some reason it wont black out to start down load. Do I need to hit the dip switch on main board. I did extract the file. any thoughts would be helpful. Thanks
  • spanky
    • Sep 2012
    • 468
    Re: sharp mx-m565n water mark
    Does the touch panel show the file on your USB drive?
    • mojorolla
      The Wolf
      • 2606
      All Sharp files from a USB must be no deeper then 1 level. If the file is in a folder INSIDE another folder, it will not see it.
      In this scenario, it will usually display two dots.
      Also, Sharp is notorious for hiding a .zip file inside of a .zip file download; you will need to double extract.
      • austonrush
        Sharp & HP Tech
        • 234
        Also make sure the USB drive you're using for firmware updates is formatted as FAT32. The Sharp cannot see NTFS formatting.
        • clark
          • Sep 2016
          • 109
          I have tried everthing. Still noting. Extracted it. display just shows but the file but wont black out. Think im missing a step here. Has any one done this on this model and can I get the step to doing it. Thanks
          • moose55
            • Mar 2017
            • 143
            Page 9-6 in the service manual details step by step instructions for the installation of the watermark firmware.
            The Moose is loose!!
            • mojorolla
              The Wolf
              • 2606
              I just did a HDD wipe on a 6240 Friday.
              When I downloaded the watermark, it was zipped. I extracted it, and THE EXTRACTED FILE WAS ZIPPED. I had to unzip a second time, move to jump drive, then SIM 49 worked fine.
              I downloaded the model you are referring to and yes, it is double compressed. See below:
