It does. There is a setting in the Web administration to turn it on, and then you can use VNC viewer on your pc to view and take control. I will see if I can pull up where it is exactly.
There are several different sections to enable, depending on what type of security is needed for remote access.
You can set the machine to only accept incoming remote connections with a physical button press on the machine, accept all connections from an IP address, or by anyone who has a password.
IP in browser will only give you the web interface.
If you log in to web interface and go to System Settings >> Operation Settings.....scroll to bottom of main window and you will see a section called "Remote Operation". There are three choices, I generally use the middle one. Select "allow", then type in IP address of the PC you will be accessing copier from, then select "Show password in PC only"
the software that I find works the best is TigerVNC viewer.
