Sharp AR-168D
    • 15069
    Sharp AR-168D
    I am working on an AR-168D that seems to have a scanner issue. The lamp will light, then search for home position then the lamp will go out for less than a second and do the whole thing all over again. The machine still seems to operate properly. There are no error codes.
    I'm not sure if this is normal for these machines. It certainly doesn't seem normal.
    Any help is appreciated.
  • mttech
    • Mar 2014
    • 127
    Re: Sharp AR-168D
    We had one in the shop. Turned it on and does exactly what you described so I would say this is normal for that model.
    • cpjim
      • May 2015
      • 47
      Re: Sharp AR-168D
      put it in one of the power save modes, I think that will work.
      • pohaku
        • 17
        Re: Sharp AR-168D
        It's normal on that copier. The scanner is re-homes it's self.
          • 15069
          Re: Sharp AR-168D
          Thanks for the responses. The customer wasn't complaining about this, it was just something I noticed.
          I will close the call.
