Sharp Mx-m264n blank streaks across scans and prints.
  • Ratchet2501
    • Mar 2017
    • 206
    noreply@gmail.com_20171017_161707.pdf
    I have seen this before but cannot for the life of me remember what was decided last time. And the streaks are not typically in the same spot. Before I started replacing/cleaning things it had either toner or developer streaks vertically where now there are blank streaks. I have cleaned the lsu glass, replaced the dv seal, replaced the cleaning roller (squeaking due to dusty environment), drum, charging grid, drum frame all look fine. I have ordered a new developer cartridge because I believe it is making noise/not doing it's job 100% (but it's back ordered unfortunately). I can't think of anything else to try/test. Is there a good way to test the lsu or is that a bad idea/direction?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp Mx-m264n blank streaks across scans and prints.
    Are the voids in the direction of paper travel? If so, most likely MC/grid contamination.
    • bryant28282000
      • Jul 2012
      • 145
      That looks like the developer housing or Fuser fingers.
      • Ratchet2501
        • Mar 2017
        • 206
        Yes they're in the direction of the paper path. On these black and white models I haven't figured out a "good" way to clean the MC without first removing the drum. Am I just missing something, other than a cleaning rod of some sort?
        Edit: I have the developer assembly ordered but I'm not going to count on that as the solution just yet.
        • techwurk
          • 127
          Tough to say with out a sample picture but look for Developer contamination at the doctor blade
          When I started servicing copiers they used toaster ovens for fusers.....I'm old
          • ZOOTECH
            • 3375
            The original post had an example .pdf - the voids were not 'sharp', but fuzzy as if lint might be arching to the drum, or something blocking DV (contamination traveling along doc blade).
            • Ratchet2501
              • Mar 2017
              • 206
              That is what I'm still leaning towards since it's not typically in the same spot. Could there be interference with the developer cartridge connection? Cause I'm going to feel slightly foolish replacing the whole cartridge if it's just got a dirty connection. Then again, when I did the maintenance on it a few months ago there was actual dirt/dust contamination inside the cartridge. I dismissed that yesterday when I was working on it because when I replaced the developer last time I cleaned the cartridge. Further proof these machines no matter the model don't like contamination.
              • xring1958
                • 166
                Why would any of the print engine parts affect scans?
                • Ratchet2501
                  • Mar 2017
                  • 206
                  Brainworms plus distraction equals bad verbage. Not scans but printouts whether copy or direct simulation prints.
                  • moose55
                    • Mar 2017
                    • 143
                    Outside shot, but make sure you look at the transfer roller also?
                    The Moose is loose!!
                    • dwarf
                      • Oct 2012
                      • 168
                      empty out the developer and check it for contamination... then run something small and flexible (small plastic ruler perhaps) through the gap between the mag roller and the doctor blade...vacuum thoroughly... at times I've found small chunks of foam floating in the developer...
                      • Ratchet2501
                        • Mar 2017
                        • 206
                        The transfer roller from the mx-311ka? Swapped that because it seemed to be squeaking. Im headed there this morning. Going to try cleaning the MC and checking the housing and connections on the developer unit. Update to follow. As always thanks for the ideas/pointers.
                        • dsmith46
                          • Oct 2016
                          • 81
                          Are the streaks always in the same spot on the paper? If so, I would check the condition of the fuser. I have seen several of these when the rollers get worn out, they no longer fuse toner. I kind of skimmed through the posts, so I apologize if this has already been mentioned.
