SHARP AR 650 Print Quality Problems
  • BlueCopy
    • Jun 2007
    • 37
    My best client has a problem... Their Sharp AR 650 has some odd intermittent print problems. The first is a print shifting problem. The first copy from the LCF will come out great, try to print multiple copies and the print will continue to shift 2 to 3 inches to the right on each copy, by copy 6 the copier has jammed at the transport and there is no image on it. Problem does not happen when copy comes from drawers. Problem #2 every once in a while copy prints a few random areas lighter than the rest. Problem #3 a stray vertical black line will appear on the paper 1 inch in from the edge after copier has been under heavy use all day. Copier is at 300,000 copies, has no error codes. Every simulations has showed no error. The drum and blade were replaced a few months ago. Any ideas? I would appreciate any suggestions. Thanks.
  • bilyahn
    • Dec 2006
    • 1470
    On the line issue #3, check the drum blade (I believe there is a small white plastic lever that you use to release tension on the blade) have had some issues with this if it is not completely free. With issue #2 I normally start with cleaning the belt transfer unit, the rollers under the belt will accumulate toner and it can cause the random light spots. On the LCF I would change the feed rollers, anytime I have had a problem with the LCF it has always been with the rollers. Have not seen this particular problem though. We had 2 of these machines and both did over a million copies. Good luck.
    Bil
      • 23009
      This sounds like really low # of copies, but #1 could be LCF clutches. The machine that was doing this for me had 5.5M copies. =^..^=
      • davistech
        New Machine
        Anybody using this model should just finally upgrade already
        • eng_nsour
          • Nov 2008
          • 10
          4 issue #1: try to check registration clutch in the paper feeder
          4 the black line in the paper i think the problem in the drum specially if it appears in the same location
          thats what i have good luck
