AR-M550 Dead touch screen
  • Buddy
    • Aug 2009
    • 285
    Hi Guys,
    I tried replacing the touch screen. What I'm getting is a faint blue light coming from the screen. There is no image at all on the screen. Machine operates fine. (People are able to print to it.)
    I was just hoping someone could tell me what and where the board is that powers the touch screen.
    Thanks,
    Buddy
    • 22999
    Re: AR-M550 Dead touch screen
    It could be as simple as a failed fluorescent backlight or inverter PWB. Can you select individual functions even though you can't see them? I would estimate 80% op panel PWB, 15% Controller PWB, 5% something else. =^..^=
    • scottshepp
      • Nov 2015
      • 2
      Try to slide the MFP PWB in and out a few times.
      • Buddy
        • Aug 2009
        • 285
        Thanks Guys,
        I tried all of the above and replacing all the related boards - no luck. Did this on a Friday. Went back to it on Monday and it was working! Working that is until I put the back cover on. Turned out to be a shorting harness. What a PIA! Thanks again.
        • Ratchet2501
          • Mar 2017
          • 206
          Originally posted by Buddy
          Thanks Guys,
          That annoying line between something amazing or something stupid, real stresser sometimes
