calibri fonts do not print job disappears
  • mlsharpskaraborg
    • Nov 2015
    • 16
    When we print from office and the fonts is Calibri, the document disappears. It have work before and just stop working, they work in a terminal server environment but nothing have update. If we make a new document and print that document is working. Have hade problem on MXC301 and MX2314 so fare and it 3 different customers. Any idees?
  • OlliK1969
    • Nov 2016
    • 311
    Re: calibri fonts do not print job disappears
    New Firmware, there is a problem with print jobs
    • mlsharpskaraborg
      • Nov 2015
      • 16
      I have new firmware. But no luck anyway
      PS drivers is working.
      Have only try this on MXC301.
      • OlliK1969
        • Nov 2016
        • 311
        MX-C301 >03.00.M1.a0 newest Version, print problems with apple
        MX-2314 07.01.G2 ->07.01.G2.f0 Unable to print PDFs from Sharpdesk mobile,MFP in release with mac,Incorrect gradient fill printing from Office 2016 for Mac/Windows
        From the Sharp-FTP-Server
        Or change truetype to bitmap ---> test
        change graphic mode ---> test
          • 23010
          I saw something like this on an HP printer. Microsoft Office Suite 2013 had just come out and my customer had just upgraded.
          They discovered that when using the default font "Calibri" several characters printed as spaces (or blank) mainly from Word, but affect the other Office applications also. It was always the same 6 or 8 characters that vanished. If you changed font to anything else, it printed fine.
          Their IT clearly understood that it was a bug in Office Suite. Since it was a server based setup, their IT simply changed the default font to Arial in all Office Suite applications. I never hear another word about it. =^..^=
          • mlsharpskaraborg
            • Nov 2015
            • 16
            Thanks fore the ides. The tips u have give have I already try and they all solves the problem.
            But I guess I need to do it that way. Maby it will start working someday again.
            Thansk
