Mxc402sc ppd2_drum
  • OperatorError
    • Aug 2017
    • 21
    Mxc402sc ppd2_drum
    Has anyone ever had to replace the main drive unit for frequent ppd2_drum jams?
    There is no flipped blade all components can move freely. K drum, dev and t belt have been replaced for quality issues and I was hoping they'd clear the code as well but still occurring.
    Machine also badly fails 50--22 auto registration.
    Thanks in advance
  • moose55
    • Mar 2017
    • 143
    Re: Mxc402sc ppd2_drum
    Sounds like you may have a bad drum drive. At first you may think it will be a little intimidating, but these are fairly easy to replace. Once you open up the rear of the machine there are literally only like 4 or 5 screws holding it in. This is one case where the service manual actually explains the removal pretty well!
    The Moose is loose!!
    • mojorolla
      The Wolf
      • 2596
      One thing Sharp has always done well is main drive motors. Pretty much all of the newer stuff is a few screws and plugs. The bigger machines even have boards on hinges so they do not have to be removed; very tech friendly.
