Mojo fix - 3070 - 6070 adf double feeding
  • mojorolla
    The Wolf
    • 2622
    I have seen this repeatedly on the new models so I developed a fix for this issue.
    Enjoy.
    Pheonix Double Feeding.pdf
  • driving lots of miles
    • Jun 2016
    • 399
    Re: Mojo fix - 3070 - 6070 adf double feeding
    We don't have a lot of these in the field yet but it sounds like it is knowledge worth having.
      • 23008
      Nice documentation! =^..^=
      • RascalMJ
        • Mar 2009
        • 174
        Enjoy.
        [ATTACH=CONFIG]38511[/ATTACH]
        I was hoping this would save me out in the field. I followed the steps and gave it a test, but I was running out of time. Still double fed a few so I left the site for now, planning to come back and try again.
        This post is fairly old... Any new tips or bulletins out now?
        • kdr363
          • Apr 2019
          • 63
          I've had luck by decreasing the tension of the separation roller instead of increasing. No need to disassemble either. Just stick a flat blade driver into the coils of the spring and twist hard enough to lengthen the spring just a mm or two.
          • RascalMJ
            • Mar 2009
            • 174
            Oh snap. I wish I would have known that prior....a bit easier for sure. Thanks though. It gives me something else to try later
