F2-78 MXM565
  • sharpie
    • Feb 2011
    • 182
    F2-78 MXM565
    Where is the humidity sensor???
  • ivan123
    • Oct 2014
    • 54
    F2-78 MXM565
    I supposed on dv box
    But F2-78 said image density sensor trouble
    • JLVisser
      • Jan 2018
      • 15
      Re: F2-78 MXM565
      It's attached to the inside frame of the main drive unit.
      • ivan123
        • Oct 2014
        • 54
        Re: F2-78 MXM565
        Confirmed
        • RascalMJ
          • Mar 2009
          • 174
          Re: F2-78 MXM565
          Was there a fix for this. Have a customer who is getting this error quite a bit. My info is that we have replaced several items/sensor (on the transfer, I believe), and even replaced the transfer.
          I do not think we have addressed the sensor mentioned above, did that fix the issue?
          • jp74msj55
            • Oct 2014
            • 149
            Re: F2-78 MXM565
            Humidity sensor # RDTCH0214FCPZ
            Item # 3 Page 120 Parts book.
            Try replacing and hopefully you should be good.
            • RascalMJ
              • Mar 2009
              • 174
              Re: F2-78 MXM565
              THANKS!!!
              That makes a lot of sense as this system is on a dock with the outside world always right around the corner. Luckily (sarcasm) they have 2 portable heaters to help keep them warm.
              I could see this sensor causing some major issues in this environment.
              • mojorolla
                The Wolf
                • 2609
                Re: F2-78 MXM565
                F2-78 is a known issue with a retrofitted upper drum seal and a mylar cover for the image density sensor. Check that this sensor is not covered in sh%t, located right under the transfer roller. Fuser cleaning on this model sucks and these frequently get gunked up.
                • RascalMJ
                  • Mar 2009
                  • 174
                  Re: F2-78 MXM565
                  I believe that sensor is the one was replaced, but thanks so much for the detailed info. Great to know why it mint be happening again.
                  Would a new process unit help with the retrofitted seal? Anything else to help for the future?
                  Sent from my XT1650 using Tapatalk
                  • spanky
                    • Sep 2012
                    • 468
                    Re: F2-78 MXM565
                    See attached
                    • RascalMJ
                      • Mar 2009
                      • 174
                      Re: F2-78 MXM565
                      Originally posted by spanky
                      See attached
                      Man....y'all are good!!!!
                      I need to get better at searching the sharp website for bulletins....etc.
                      THANKS
                      • RascalMJ
                        • Mar 2009
                        • 174
                        Re: F2-78 MXM565
                        See attached
                        We tried the humidity sensor with no luck.
                        Just received the countermeasure shielding and will try that asap. Question though. Should we look into replacing the imagine density sensor, or a good cleaning is ok? Also would it be advised to replace the DV as this error has been ongoing and could have effected "the mix"?
                        • tmaged
                          Owner/Service Manager
                          • Oct 2008
                          • 1885
                          Re: F2-78 MXM565
                          I have a MX-M465N that we're fighting this code on. We've replaced the supplies, Cleaning web & entire transfer unit that has the new sensor in it. Also have updated firmware that addressed the code when coming out of sleep mode. Any other things that you've fixed it with ? Is the temp/humidity related to this code ? We have not tried that. Thanks for any input !
                          Hope that helps !
                          -Tony
                          www.dtios.com
                          Become a fan on Facebook
                          • RascalMJ
                            • Mar 2009
                            • 174
                            Re: F2-78 MXM565
                            I believe ours ended up being related to a poor connection between the right side door and the machine. The connector was not lining up properly. Too some work and reforming the Earth spring {metal spring\plate}
                            • Demon33
                              • Jan 2019
                              • 38
                              Re: F2-78 MXM565
                              you can also check in 44-09 if the values are good.
                              If not clean the transfert roller with dry cloth , the sensor & do a 46-74 again.
