Sharp MX 3070 E7 A7 Error Code. Machine powers off and on now
  • Doug James
    • Jan 2012
    • 935
    #16
    Re: Sharp MX 3070 E7 A7 Error Code. Machine powers off and on now
    What was your ultimate fix for the E7-A7 error?
    It's been a few years but it was the MSATA card. I got it directly from Sharp from a local dealer. I then decided to start focusing on Kyocera. But I believe the MSATA fixed the issue.
    • copiertec
      • Jan 2016
      • 2206
      #17
      Thanks for the help Doug James. It turned out to be the MSATA for me as well. I'll look to see if anyone has successfully cloned MSATA cards here.
      • mloudy
        • Oct 2015
        • 787
        #18
        I use HDD Raw Copy Tool along with a Apricorn mSATA Wire case to program blank mSATA cards from known good images. Sometimes I can bring a bad mSATA card back and install it in another machine and it will work so I can pull info off of it. I never copy or clone off of them though because I fear I might transfer some weirdness off of them.
        It is hard to find new mSATA cards now so buying them from Sharp has been my only option lately.
        I highly recommend cloning all machines to a flash drive whenever you are in front of them and attaching the flash drive somewhere on the machine. Then when a SD card, eSATA or HDD fails you can at least get it back to a fully functioning machine pretty quickly. I buy 512MB drives for around $2.10 each in 10 packs. Even if one out of ten comes in handy at some point I think it is well worth the money.
        • copiertec
          • Jan 2016
          • 2206
          #19
          Thant's a good idea with the flash drive. On the 40 series we always had a back up sd card inside the machine or on a techs computer.
          • copiertec
            • Jan 2016
            • 2206
            #20
            Here is a good link to follow up on these errors as well.
            Interesting find: Msata cards
