Sharp mx-3140 locks up after exiting simulations
  • lenovos
    • Oct 2012
    • 141
    HI all we have a Sharp MX-3140 that after exiting simulation, will not come back to ready. Display stops at please wait. If we manually turn power on and off copier will recover.
    Earlier this month we had a MX-2615 that was dead except for green led and cooling fans. Display was black. Machine recovered after reseating MFP board and mother board. Not sure what to make of that one, any comments are welcome.
    Re: Sharp mx-3140 locks up after exiting simulations
    What have you done?
    Have you looked on the report to see if there are any non-reported errors?
    try re-seating connectors on the boards
    firmware update
    • austonrush
      Sharp & HP Tech
      • 242
      I'd update the firmware, may be the beginning of an SD card failure.
      • Ratchet2501
        • Mar 2017
        • 206
        Also can be due to a firmware update that was partial, if they were upgraded recently and anything was missed or not included by the run all option. Can cause problems.
        • lenovos
          • Oct 2012
          • 141
          Hi thank you , firmware was the first thing that i tried. Reseating MFP board seems to have solved the problem.
          • Ratchet2501
            • Mar 2017
            • 206
            Never hurts (much) to run through the gamut of stupid things
            • lenovos
              • Oct 2012
              • 141
              What have you done?
              firmware update
              re-seating MFP board seems to have solved the problem.
              Thank you
              • lenovos
                • Oct 2012
                • 141
                They are not so stupid when the work!
                You are exactly right.
                • Ratchet2501
                  • Mar 2017
                  • 206
                  True, but having gone from working with/maintaining an acid plant to dealing with copiers, these darn things are sensitive lil turds to me at least.
