Customer let waste container fill over. cleaned due to everything locked up. But cant get the color to line up together. Tried registration adjustment and machine says no go. gear on transfer unit good. And cleaned all of it and drum units. any ideas please let me know. Thanks
sharp mx3110n. color registration off
Re: sharp mx3110n. color registration off
These are the possible fail codes......what does the machine really say???
Trying to help...Comment
You may want to set 50-22 to defaults, then try the auto reg/drum phase again.
The color calibration may have to be started from scratch."You can't trust your eyes, if your mind is out of focus" --Comment
Hey there ,
go into sim 50-20 and look , if it on of the first entries are set to 1 , you have a problem with toner in the DV-boxes .
level of toner is to low . solve these problem .
if you have the problem fixed , set the entries what is 1 to 100 and perform the sim 50-22 again .
michmichComment
thanks for all your help. just went back out there. tried color adjustment. no good. I did notice it was just the magenta off. I know this is strange swap magenta and cyan drums and now everything is great. any thought to why that worked?. thanksComment
It was "AM or FM"...'another miracle or freeking Magic' ๐"You can't trust your eyes, if your mind is out of focus" --Comment
