sharp mx3110n. color registration off
  • clark
    • Sep 2016
    • 109
    Customer let waste container fill over. cleaned due to everything locked up. But cant get the color to line up together. Tried registration adjustment and machine says no go. gear on transfer unit good. And cleaned all of it and drum units. any ideas please let me know. Thanks
  • mansart
    • 852
    Re: sharp mx3110n. color registration off
    What do you mean by "machine says no go"? when you do 50-22, what is the result?
    • clark
      • Sep 2016
      • 109
      machine say failure. I tried it 4 times and each time registration failure
      • mansart
        • 852
        These are the possible fail codes......what does the machine really say???
        Trying to help...
        • clark
          • Sep 2016
          • 109
          there are no codes on machine. if you copy a driver id the colors are off. even if you print a color image the colors are off. tried to do registration adjustment. it trys but after says
          failure.
          • ZOOTECH
            Senior member of CRS
            • 3375
            You may want to set 50-22 to defaults, then try the auto reg/drum phase again.
            The color calibration may have to be started from scratch.
            • Michmich123
              • Nov 2013
              • 24
              Hey there ,
              go into sim 50-20 and look , if it on of the first entries are set to 1 , you have a problem with toner in the DV-boxes .
              level of toner is to low . solve these problem .
              if you have the problem fixed , set the entries what is 1 to 100 and perform the sim 50-22 again .
              michmich
              • mansart
                • 852
                when you do 50-22 are you seeing these screens above?
                the actual color registration......is the defect consistent? meaning for example, does the cyan and magenta always "mis-register" by the same distance?
                • Bernard
                  • Aug 2011
                  • 14
                  I would definitely swap out the transfer unit if you have a used one. At least you'll know it's good.
                  • clark
                    • Sep 2016
                    • 109
                    thanks for all your help. just went back out there. tried color adjustment. no good. I did notice it was just the magenta off. I know this is strange swap magenta and cyan drums and now everything is great. any thought to why that worked?. thanks
                    • ZOOTECH
                      • 3375
                      It was "AM or FM"...'another miracle or freeking Magic' 😜
                      • clark
                        • Sep 2016
                        • 109
                        Regarding the picture of 50-22 the machines say cyan and magenta NG. yellow ok. machine came back today same problem. any help would be nice. Thanks
