Sharp MX 3070 "Code Error" Updating firmware after replacing Msata and control board
+ More Options
Posts
  • Doug James
    • Jan 2012
    • 935
    [Dead] Sharp MX 3070 "Code Error" Updating firmware after replacing Msata and control board
    This machine is giving me hell. Long story short... I replaced the control board (Twice) and the Msata board (Twice) and still comes up in CN mode with the six squares. No matter how the dip switch is positioned. We tried to load firmware and it gives us a "Code error" The eproms were switched to new board. Any ideas would be a GREAT Help ... Thanks so much
  • Paulm
    • 69
    Re: Sharp MX 3070 "Code Error" Updating firmware after replacing Msata and control bo
    Where did you get these MFP-SCN boards? Could possibly have gotten one with a DSK installed? Just a thought.
    • Doug James
      • Jan 2012
      • 935
      We got the boards from Hytec I'm not sure what DSK is (Foreign Firmware ?)
      • Paulm
        • 69
        Data Security kit. When you install on one of these units before you install the firmware it will only boot to the cn screen. That's why I was wondering. Does it boot to the CN screen with the original board in?
        • Doug James
          • Jan 2012
          • 935
          We Couldn't tell, The control panel wasn't working... The machine operated for 4 months prior to breaking
          Here was the workflow...
          Initial service call- On power up the machine was turning off then on then off then on.
          I replaced the Msata board per Sharp tech bulletin regarding power up issues.
          This fixed the Power on and off issue but the Control panel was not working and the diagnostic lights on the LED were not on as per tech bulletin so I replaced the controller board.
          After replacing the controller the copier came up but only in CN test mode. I tried to install the latest firmware and the machine would not accept the firmware "code error"
          I installed another controller board again the firmware would not install.
          I installed another Msata board again the firmware would not install.
          • mttech
            • Mar 2014
            • 127
            You can check to see if the machine originally had a DSK installed by looking for the extra PWB that would have been installed. Check your Installation Manual for exact locations of the extra PWB and the replacement ROM chip for the DSK. If it is installed, download the firmware for the MX-FR52U and try installing that, instead of the firmware for the MFP
            • Doug James
              • Jan 2012
              • 935
              That makes perfect sense... I sure apprecviate your help... That's it... I loaded that firmware and it worked Thanks so much !!!
              • JR2ALTA
                • Feb 2010
                • 2033
                Bravos all around!
                • ctuinstra
                  • Apr 2011
                  • 49
                  For future searching by other members, the specific message is "Code Signing Error". I believe we have the same issue and may have a DSK on it.
