Fuser release pressure bearing holder
  • JLSam
    • Jun 2015
    • 605
    I've had the fuser pressure bearing holders break on a Sharp MX-M565N. Parts guide> Section 41>Part #6.
    Because it's broken, I'm not sure which tier of tension for pressure should the spring be loaded to on the new part. Looked in SM, can't find the information I need.
    Do you know the default pressure setting?
    Sent from my ONEPLUS A5000 using Tapatalk
  • mansart
    • 852
    Re: Fuser release pressure bearing holder
    I don't find mention of it in manual.
    I would start at lowest setting and try. If fusing does not happen properly ......bump her up a notch
    • JLSam
      • Jun 2015
      • 605
      At the moment we have it at the highest setting. Not sure if that is the default, and the more important question is - will it wear out the pressure roller faster at the highest tension? This is why I want to know the default tension setting.
        • 23002
        What media type is your enduser using primarily? Naturally, the lightest spring pressure that still fuses will make your fuser rollers last the longest.
        Plain paper 60.2-110 gsm: lightest
        110-218 gsm: medium
        Heavy 218-270.9 gsm: heaviest
        I think I'd test the customer's media on the lightest setting. If all the media passes the scratch test you're done. If not try the next heavier pressure setting. =^..^=
        • JLSam
          • Jun 2015
          • 605
          110-218 gsm: medium
          Thank you for your response. This machine didn't come from a customer, but from a machine that is being refurbished in the shop, nevertheless, we are going to put in the lowest tension settings and test. Will respond in a few days with results in case another tech comes across this issue too.
          Nevertheless, if someone does know the correct default tension, please post. Thank you.
