Dropout on duplex
  • teklife256
    • Sep 2012
    • 164
    Dropout on duplex
    While duplexing a print job dropout occurs. This is a MX-6240N with known good dev, drums and mc units. Single side looks good all day, dropout only occurs on duplex in bottom 3/4 of print where image is densest. Any ideas?
    Thanks in advance
    • 23003
    Re: Dropout on duplex
    It would help to see a sample. That being said, I think that you should focus on the fuser inlet guides and the duplex paper loop/buckle. I think that you'll find that the void exactly aligns with the moment that the second side enters the bite of the fuser rollers.
    When the second side is imaged the paper already has some curl from it's first trip through the fuser. That means that the leading edge of the paper will strike a different area of the fuser inlet guides, possibly built up with toner, scarred, or out of adjustment. The traditional method of adjusting the height of the fuser inlet guide is to take a business card and start it into the bite of the rollers. The card should be perpendicular to the rollers ... maybe an illustration is in order:
    The card should touch the heat belt just before it enters the bite of the rollers. I apologize for the illustrations. It's just quickly hacked out of the service manual via screen shots.
    If the duplex loop adjustment is too great you can also get that void.
    How heavy is the media? Media weight can also play into this. =^..^=
    • Dartplyr
      • Feb 2016
      • 11
      i've seen problems with secondary trans belt. first sided looked fine. second side in high image areas started to break up image. looked like lots of pinholes in image. i replaced belt. fixed problem
      • teklife256
        • Sep 2012
        • 164
        Ibwill look into that today and upload a sample. Thank you for the insight.
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          When we refurb these fuser units its the inlet guide is replaced as they get in a bad state.
          It didn't say that I couldn't do it in the manual.
