Sharp mxm 314n
  • davebtech
    • Apr 2015
    • 176
    [Misc] Sharp mxm 314n
  • MWR1424
    Re: Sharp mxm 314n
    Replace SD card. We use a program "HDD RAW Copy Tool" to copy new SD cards when we have them and then we keep the file so when we have one that goes bad, usually we can just copy over the bad SD card with the stored clean copy. Usually works just fine. You must copy the SD card while it is new before installing in a machine. Has saved us a ton of money. Usually the SD card is not bad, it's the program file on the card.
    • davebtech
      • Apr 2015
      • 176
      Re: Sharp mxm 314n
      Ok will do,thanks for the great info.Do you know if I can grab an sd card from a working 264 and try it in 314?
