ARM455N locking up
  • rh112
    • Dec 2007
    • 51
    ARM455N locking up
    Have a 455 that will lock up and keypad wont function power switch will not turn copier off only way to get it to reset is to unplug then can run a few copies (as few a 2 and sometimes up to 20) and will locks up again Even had it lock up while running 22-6 Reset error log no errors or jam code show up
    Was instructed to reformat hard drive this locked machine up also
    Replaced hard drive and same problem can not format new hard drive
    What would be next things to check
    Thanks in advance for any help
  • DavePo
    • Jul 2008
    • 305
    How about swapping out the flashroms from another machine. Also try the MFP PWB.
      • 23006
      On Sharp products it's common to have accessories cause such problems. I would start out by disconnecting every non-essential accessory, then run it. If your problem vanishes. Power off, reconnect (1) accessory, power up, then re-check operation. Repeat until you problem re-occurs to pin down the offending accessory.
      There have been a few occasions that I've done this, and the lockup never re-occurred. I guess it's just FM.
      • rh112
        • Dec 2007
        • 51
        Thanks blackcat your solution worked and as you said must be FM
