Mx 3560v not offsetting documents when in sort mode.
  • leo34staffs
    copierman
    • Aug 2007
    • 499
    [Misc] Mx 3560v not offsetting documents when in sort mode.
    Hi all.I visited this machine today where the customer said documents were not being sorted correctly. So I told them to hit the offset button. Still no joy. So I went and visited the machine and the motor will not shift the exit when offsetting . The motor (osm) has been swapped and still no shifting. I was expecting to get an error code but the motor does not even function in output check. Any ideas??
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • igi
    • 1507
    Re: Mx 3560v not offsetting documents when in sort mode.
    Hi does the motor runs if you do 6-01 sim OSM Offset motor?
    • joe_vanacker
      • Dec 2016
      • 28
      Can you check sim 55-01 swn24 data 7 is 0?
      • leo34staffs
        copierman
        • Aug 2007
        • 499
        What does that bit switch do?? I have tried output check in sim 6-1 and the light just goes on and off when selected. The osm does not move . Neither does the machine give any error codes when the motor does not move. Will check that sim out.
        • joe_vanacker
          • Dec 2016
          • 28
          if you have a finisher installed, you do not have a shifter motor installed.
          when testing the machine without the finisher the machine would give l4-11 error, with the data 7 on 1 you can test the machine without having to install a shifter motor.
          • leo34staffs
            copierman
            • Aug 2007
            • 499
            Where and how did you find out about this sim?? I have just been told by sharp technical to check this. Finger's crossed it's something as silly as this.
            • leo34staffs
              copierman
              • Aug 2007
              • 499
              That bit switch sorted it so many thanks for the input, this must have come set like this from factory.
