Sharp mxm 264n
+ More Options
Posts
  • davebtech
    • Apr 2015
    • 170
    Sharp mxm 264n
    Doc feeder jams at slit/scanner glass. Replaced feed/sep tires,cleaned sensors glass never seen this before....anyone run into it? Thanks for any help Dave
  • copiertec
    • Jan 2016
    • 2187
    Re: Sharp mxm 264n
    Have you checked the hinges for breakage or alignment such as loose screws?
    • Blizzoo
      • Aug 2013
      • 605
      Re: Sharp mxm 264n
      I know I had a similar jamming issue on a b/w Sharp a long time ago, jamming when original reach the slit glass and a 'Check SPF/RSFP' error if I remember correctly.
      The fix was to clean optics/white reference as it looked somehow the scanner won't find his home position for Doc scans, I might be wrong as I don't know your current model.
      • Hansen88
        • 1053
        Re: Sharp mxm 264n
        I had one,same feeder but different machine doing that. I replaced the sensors even though they tested to be working. Did not fix. It ended up being the feeder control board.
        • davebtech
          • Apr 2015
          • 170
          Re: Sharp mxm 264n
          Great info everyone thanks going there this morning.
          • davebtech
            • Apr 2015
            • 170
            Re: Sharp mxm 264n
            Thought I would let everyone know on this it was the feeder control board.
            • davebtech
              • Apr 2015
              • 170
              Re: Sharp mxm 264n
              [QUOTE=davebtech;638227]Thought I would let everyone know on this it was the feeder
              Jam came back replaced feeder photo sensor part #pshvhpgp1a73a+-18 photo sensor ,2 number 8s in part manual it was the one closest to front of machine .
