Sharp M502n photoprint problem
  • Service@PRT
    • Oct 2016
    • 181
    I have tis old machine mx m502n black photocopier, which good in print and copy text but with photo not good heres the sample print out or copy of id.
    Sent from my HUAWEI VNS-L21 using Tapatalk
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • mansart
    • 852
    Re: Sharp M502n photoprint problem
    Have you tried Exposure>>Photo ??
    • Service@PRT
      • Oct 2016
      • 181
      Yes. Same problem. I change developer, corona, drum. And reset maintenance counter as procedure.
        • 22995
        Yeah, what original type have you selected? Text probably isn't the best choice for portraits. =^..^=
        • Service@PRT
          • Oct 2016
          • 181
          Text and photo type selected. But actually tried all types to try if theres difference but same result.
            • 22995
            Did you clean the optics?
            • Service@PRT
              • Oct 2016
              • 181
              Yes.
              • spanky
                • Sep 2012
                • 468
                Have you run sim 46-74
                • spanky
                  • Sep 2012
                  • 468
                  Sorry, on this machine it is sim 46-24
                  • Service@PRT
                    • Oct 2016
                    • 181
                    Cannot run machine on 46-24.. after sometime in the middle of the run it stop. Then execute button become unshaded. And cannot rerun again.
                    • ivan123
                      • Oct 2014
                      • 54
                      • Service@PRT
                        • Oct 2016
                        • 181
                        Yep its A4R to work. But its stopping in the middle of calibration.
                        • ivan123
                          • Oct 2014
                          • 54
                          Then I would do like this:
                          1. Update of firmware
                          2. Clean the image density sensor
                          3. Sim 44-06
                          4. Sim 44-26
                          5. Then sim 46-24
                          Few question more:
                          Did you try to print some photo?
                          Quality?
