is there diff w/ AR M277 and AR M317 DV unit?
  • Sam Tofu
    • Dec 2007
    • 130
    Have a M317 with bad mag roller. Looking over our old scrap parts machines. Most DV units and misc parts pulled and set in piles. Unfortunately, some of the M317 and 277 series got mixed together. Looking over the DV units ALL look the same but I know at least one of them is a M317 while most are M277 series.
    Thinking may be essentially same although parts manuals list a diff part number.
    Can't tell. Has anyone reading this swapped out DV units from the really older M277 series with the somewhat older M317's
    TIA
  • bburp
    • May 2016
    • 11
    Re: is there diff w/ AR M277 and AR M317 DV unit?
    I believe dv units will interchange but I think process units will not fit
    • Sam Tofu
      • Dec 2007
      • 130
      Thanks, appreciate re DV ? ! Yes you are correct re process units being diff.
      • Toner Boy
        • Aug 2007
        • 366
        pretty sure they will interchange, even as old as AR275 possibly (think we did that 1x)
        • axyun
          • Aug 2007
          • 1323
          I would think if there is a difference it is probably minor as the part # for AR-M277 dv unit is CBOX-0001JS5G and the part # for AR-M317 dv unit is CBOX-0001JS5K
