Change developer unit message on MAC print driver
  • bilyahn
    • Dec 2006
    • 1470
    Interesting problem. This client has mostly MACs and some of them get a "developer unit needs to be replaced" when they send a print job, print job still goes through. Not all of the MACs just some of them. There is no corresponding message on the unit nor is there any maintenance due. Windows drivers do not show this message. The message does not state which one just that one of them needs to be replaced.
    I checked this post: http://www.copytechnet.com/forums/sh...developer+unit but it doesn't seem to apply. Going out there today to see this message in person. Figure I'll check the MAC versions on the machines that are doing it and possibly update their drivers.
    Wondering if anyone has seen this before and what the solution was. I was out there previously but could not duplicate the message.
    Thank you for your time and effort in this matter.
    Bil
  • spanky
    • Sep 2012
    • 468
    Re: Change developer unit message on MAC print driver
    Common MAC issue telling you to replace a consumable.
    It is a MAC issue and the print driver update or the MAC O/S update is what probably caused it.
    • mansart
      • 852
      Inaccurate information for printer supply… - Apple Community
      • guitar9199
        • Sep 2016
        • 1100
        Feel free to ignore it.
        Mac print drivers are NOTORIOUS for throwing this message. Apple's attitude is, "It doesn't do that on OUR equipment...you need to make your machine more compatible with us!!"
        It does it pretty much across the board too... Konica, Canon, Ricoh/Savin, etc....
        • bilyahn
          • Dec 2006
          • 1470
          Thank you for the quick responses. I will inform our client.
          Have a great day.
          Bil
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            • Toner Boy
              • Aug 2007
              • 365
              Please update us with what supply item (assuming that's what triggered it) caused the driver message, if you find it.
              • bilyahn
                • Dec 2006
                • 1470
                There were no maintenance or supply messages due on this machine. No messages on unit of any kind just on the print window and then only on 2 of their MACs.
                Bil
                • mickj
                  • Apr 2015
                  • 33
                  Did you check with the web browser as the message on the machine could be turned off with soft switch
                  you could always reset the dev counters
                  • mojorolla
                    The Wolf
                    • 2611
                    This is a common message for all Sharps from certain versions of MAC OS, :Mountain Lion" being the most troublesome. You can fix this by completely removing the current driver and update to the latest and greatest, message will cease to appear.
                    • onetek
                      • 318
                      If push comes to shove,
                      At the end of the PPD file add the following line exactly as written:
                      *cupsSNMPSupplies: False
                      You 'll get rid of all the supplies related status messages this way.
                      Th.
