AR-M355U upgrade to N
  • kirkeb
    • Dec 2012
    • 31
    Think I know the answer to this but here goes. Customer has U version of AR-M355. Wants to make it networkable. I have a network expansion kit - MX-NSX1- network card, ROMs and HDD that was pulled out of a AR-M455. I need a new product key to make it work in the 355. I know to get a product key in the past you had to have the serial # of the machine you wanted to install the kit in and the application number in order to get the product key. I have the former but don't have the latter. As I said I think I already know the answer, but thought I'd ask. Is there any way to get a new product key for it since I don't have the application number for this kit?
  • Craigcul
    • Aug 2017
    • 70
    Re: AR-M355U upgrade to N
    Hi unfortunately the product key is locked To the serial number and model number that it was first register to you would have to purchase the network kit as new and apply for the product key.
    Sent from my iPad using Tapatalk
      • 23009
      I'm sure that you don't want to hear this, but this machine is way too old to justify this sort of investment, were it possible or not. Just sell then something a decade newer. =^..^=
      • kirkeb
        • Dec 2012
        • 31
        That's what Sharp tech support said. lol
        • kirkeb
          • Dec 2012
          • 31
          And my bad. It was the AR-P21 kit not the MX-NSX1. Was doing it from memory and got the two confused.
            • 23009
            This is one of those situations where it can go bad quickly. You invest a lot of time and/or money on a very old machine with few or none replacement parts.
            So let's say that you are successful today, and bill them say $500 (should be more). The first time it needs an uncommon consumable like say a paper stop assembly ... well you can't get it and the machine is a doorstop. "I just spent $500 only a month ago, and now you're saying it can't be fixed!!! ... blah, blah, blah."
            • JLSam
              • Jun 2015
              • 605
              Or those stupid paper feed couplings in the AR-D28 LCC, or the AR-FN6 FINISHER!! YOU think it would be common, and readily available. But nope, nowhere to be found. We buy these machines already old and destroyed on the cheap, just to be able to strip it of those odd parts that are no longer available. (US Gov has a TON of these machines breaking and in need of repair still).
