Sharp MX M503N fuser web question and 25-2 dev calibration question
  • tonerjockey
    • Apr 2014
    • 567
    Hi guys/ girls.
    i just did the fuser maintenance kit on this box, as well as the charger kit, drum and developer.
    i estimated 1.5 hours, took about 3.5 after running out 3 times to feed the meter. ( but kept the original estimated charge) next time, i will bid higher.
    my question, and i used all OEM parts. the existing fuser web shafts, both had plastic spacers, on the non drive side. they were installed in such a way, i believe that one spacer/ collar has a rubber ring and i believe it is a friction fit against the other collar. maybe to keep web tight?
    these collars, fit on the end of the aluminum web material shafts, and have splines to engage the grooves or notches on the two shafts.
    the new web material shafts, didn't have these notches, so i could not use the original collars that were on it, and there wasn't any new style? couplers in the kit to take their place.
    was there a bulletin? are those to be left out.?
    i thought that without them, the web would unwind around the fuser roller, but i tried to unwind it and it is still held by the drive gear latch pawl. the machine was working fine when i left though.
    any advice would be greatly appreciated.
    PS, when doing 25-2 dev calibration, the display said i think, "check drum" was the calibration carried out with this message successively?? i would have thought a new drum and developer, would have had slightly darker copy density.
    thank you, have a great day, Jim
  • copiertec
    • Jan 2016
    • 2205
    Re: Sharp MX M503N fuser web question and 25-2 dev calibration question
    As far as the web, I would check the parts manual and see where those spacers are placed for the web. The reason it is saying "check drum" is because you need to reset the drum counter after replacing it, refer to section 8-3 in the service manual, on the correct procedure to reset drum counter. Furthermore, refer to the calibration procedure(s) after replacing drum and developer...also, located in section 8, ADJ 12A, that may resolve your light copy/print issue.
    • tonerjockey
      • Apr 2014
      • 567
      Thank you copiertec.
      I'll try your suggestions. I really appreciate your help.
      Have a nice weekend.
      • Jhonjon
        • Sep 2013
        • 208
        Originally posted by tonerjockey
        Hi guys/ girls.
        First, regarding the fuser web in 283,363,453 and 503 series. I have a lot of this machine, but i didn't see any plastic spacer and rubber ring when ever i replace the web. The unit only have a gear, 2 metal shafts and one with 2 spring and a sponge roller. When replacing the consumables reset first the drum, developer and maintenance and be sure to remove the toner when calibrating the developer to prevent overtone.
        • mickj
          • Apr 2015
          • 33
          The web for these machines is MX503wc and needs the notch at the ends of the rollers to drive the web and comes as above with two steel bars, sponge roller, and the web
          so I would think you have fitted the wrong web? and needs to be replace as soon as possible as the new rollers will get damaged if left.
          did you do these sim after you reset the copy counters for drum and dev?
          46-24
          46-02
          46-04
          46-05
          46-09
          64-05
          • tonerjockey
            • Apr 2014
            • 567
            i didn't do any sims except for the 25-2.
            the one new web shaft on the drive end, did have one notch, that fits into the drive gear.
            its the other side that had these collars, with two notches on each shaft. the new one only had the notch for the drive side.
            i double checked the Sharp box, and it was for the MX M503N, same as the machine.
            • tonerjockey
              • Apr 2014
              • 567
              interestingly enough, the two ? collars or friction hubs, are not shown in the parts manual.
              so, apparently, they are not used any longer?
              possibly, there was a mod kit to convert an old style web housing to the new style web??
              but, that's what i found.
              i will go back this week and do the basic stuff i somehow forgot to do.
              i guess i just figured resetting maintenance counters was somehow not needed??
              the machine is around 350K, and there was no indications on the display or anywhere else, that it was due for the PM, the drum or developer. the check drum light was only on when performing the calibration.
              so, i guess that's why i lost my memory.?
              i really appreciate all your help. have a great evening, Jim.
              • Hansen88
                • 1066
                I have seen those collars on the web before. Like you said the new web rollers are not made so you can use the collars. I throw them out and I have not had any problems from not using them.
                • onetek
                  • 318
                  re web: The previous tek used web units from 4101 series (MX-410WC).Thats what we do here. They have those "washers".
                  Th.
                  • tonerjockey
                    • Apr 2014
                    • 567
                    thanks for the updates guys.
                    i guess since i only have one MX M 503 in the field, i will leave it as is.
                    i really appreciate the info about them not being needed any longer, and that it works properly without them.
                    i was trying to download the picture last night from phone of them, but it kept failing. i may try on the desktop so members might see what i am referring to.
                    Have a great day.
                    • tonerjockey
                      • Apr 2014
                      • 567
                      i am trying to attach the picture of the old hubs. i dragged it to the add pane, but its in another window??
                      i posting hoping that it will appear on the post.
                      • boutn
                        • Jun 2016
                        • 547
                        We are using the MX410WC on these...works perfectly. You only have to swap the connector.
                        As for the light copies, clean the sensor in the transferunit and do SIM 44-2
                        • tonerjockey
                          • Apr 2014
                          • 567
                          thank you for that.
                          i went back a few days ago and completed the resets on PM, drum and web. the developer had reset with the calibration.
                          the 64-05 ? 12A exposure adjustment calibration had a "execute" button, and i never was able to know if it actually did anything. some things had the "execute", and then a "yes or no". i tried the calibration several times, even pressing "start" and another time clear.
                          the machine should acknowledge that it was completed with a "completed" indication.
                          but when i made copies before and after in "auto", they looked the same. not bad. in "text" mode, they looked very nice and robust.
                          so maybe auto like on Canon, is sorta a toner save middle of the road.
                          customer is happy, and there wasn't any web material coming out of the fuser, so apparently as stated above, those plastic collars are no longer used.
                          Happy Friday and have a great weekend, Jim.
