Sharp MX 4050- Feeder problem
  • Jessetech
    • Mar 2014
    • 38
    Hello Guy's and Gal's hope you guy's can help
    Have this machine and cust says that feeder does not recognize size nor the paper when they put it on DSPF, wondering if anyone has the SM or atleast if you can scan over the feeder pg to see where sensors are so that I can clean, thanks in advance
  • Jhonjon
    • Sep 2013
    • 208
    Re: Sharp MX 4050- Feeder problem
    • Jessetech
      • Mar 2014
      • 38
      Thanks boss, this will surely help, bought the manual just a little while ago but i appreciate it and your time, owe you 1
      • Jhonjon
        • Sep 2013
        • 208
        Welcome.
        • bburp
          • May 2016
          • 11
          I had a similar issue with a DSPF. The width sensor was malfunctioning. It wanted to read A4 paper most of the time. It turned out to be a broken harness at the width sensor connector underneath the tray that raises up. Seems that they made it just too short and a wire broke at the connector. I was able to make the wire connect but later on the others broke also. I finally had to replace the small harness about a foot long. Remove front rear and middle DSPF covers. I think the tray lifts out and the connector I am talking about will be on the right side of that tray. You can also reach the legnth sensors there to swap and test.
          • boutn
            • Jun 2016
            • 547
            I had exactly the same problem a while ago
