mx-m465n
  • mike2565
    • Aug 2018
    • 12
    [Misc] mx-m465n
    is anyone having problems with the sharps mx-m365n,mx-m465n and the mx-m565n where the drum keeps flipping the blade and going into c1-10?
  • mansart
    • 852
    Re: mx-m465n
    I have approx 60 of these machines in a school district and have not see that problem......
    • rufio311
      • Jun 2013
      • 12
      Re: mx-m465n
      Yes, I've seen this quite a few times on those models. Just have to make sure the drum is powdered really well.
      • Jhonjon
        • Sep 2013
        • 208
        Re: mx-m465n
        Have a lot of this machine but never encountered flipping the blade. maybe you can ask the user how do they use the copier...maybe after they use turning off the machine and use after a couple of days or week . Environment also can contribute, maybe less ventilation, heat from the fuser doesn't push by the fans. Location... Or try to replace the Process unit. Good luck!
        • moose55
          • Mar 2017
          • 143
          Re: mx-m465n
          As rufio311 stated, lube the drum quite a bit. I have a lot of these machines in the field, and I have seen that you can not lube the drum too much. They are notorious for flipping blades!
          The Moose is loose!!
          • mike2565
            • Aug 2018
            • 12
            Re: mx-m465n
            thanks everyone i've found that the filter in the back of machine gets plugged at about 700,000 to 800,000 copies and isn't drawing all the heat out.
            • bigdaddyooo
              • Dec 2014
              • 206
              Re: mx-m465n
              What I have seen is that when you change the MK and install the drum seals, put the blade in first THEN install the seals. When you do the seals first you can install them incorrectly and the blade cant move towards the augar causing flippage. I know this because I flipped 3 blades in a row then changed to blade first then seals and never had one flip ever again.
              Are you the police? "No ma'am, were musicians"
              • dsmith46
                • Oct 2016
                • 81
                Re: mx-m465n
                I have seen this countless times on the 465 and 565's. Sometimes the blade flips bad enough that it is wedged against the drum, making it difficult to take the drum out. This is important to pay attention to, as these process units are very cheap and flexible. When they wedge this bad, it torques something in the frame, making future blade flips inevitable. The process unit is not too expensive to replace. Also, we have had success using the blade from a 503mk kit instead of the one in the 560mk kit.
                Good luck!
                • repn1999
                  • May 2010
                  • 310
                  Re: mx-m465n
                  Make sure you are using yellow and 312 steric acid powder on drum AND blade. Clean off old stuff first and use a lot. There is a bulletin on which powders to use fyi.
